Solved: Access denied writing to usb
juliuschai
Post by juliuschai » 31 Oct 2017 00:32
I've got a 15 gb usb filled with 2 partitions (5gb linux os, 10 gb ext4 partition). I ran HxD as admin, picked my usb from the devices list, uncheck the read-only option, wrote my changes, pressed ctrl-s, and boom a pop-up "Access denied" shows up.
I can write my usb using windows (adding text files, folders), edit partitions via device management.
I'm running win 10 (not sure if that helps)
P.S: i've tried turning it on and off, doesn't help :(
Re: Access denied writing to usb
Post by Maël » 31 Oct 2017 13:17
Have you tried HxD 2.0 RC?
In general the issue is that since Vista Windows denies write access to any mounted partitions. HxD 2.0 tries to automatically unmount them if possible.
Otherwise you can try to unmount any paritions on that disk using disk management before trying to access it in HxD (you'll have to open the physical disk then, because the logical disks/partitions will not be available due to unmounting them).
Let me know if that worked.
juliuschai
Post by juliuschai » 31 Oct 2017 15:05
i kinda gave up on the problem and decided to just edit the iso instead of my flashdisk. So i won't be able to try this solution :| Sorry!
juliuschai
Post by juliuschai » 31 Oct 2017 15:40
HxD 2 RC works for me, Thanks!
