Hi I need the option of adapting the windows contents in fit-to-length/portrait orientation.
Thankyou; Dave
Solved: Adapt to window length..
Re: Adapt to window length..
You have to be a bit more specific.
There is an icon in the toolbar that activates "adapts to the window width".
Same for printing.
What are you missing?
Same for printing.
I'm missing exactly what I said, an adapt to length button, ie opposite to the icon on offer currently.
My monitor in portrait orientation, HxD will adjust to this orientation.
-Dave
-Dave
HxD always adapts the content to the height (=length) of the window, depending on the size of the file you display.
To have the size of the window adapt to your screen size, maximizing should help.
If you mean something else with length, please provide clarification using screenshots that show what happens vs. what you expect. Remember not everyone has a monitor in portrait mode (and thus it is not obvious why it matters; screen resolution just changes), nor are terms as unique in meaning as it might seem....
Re: Solved: Adapt to window length..
No further feedback, so I assume the problem was solved.
Closed.
Closed.
