Error when writing to disk end
Writing to the end of a 4 TiB disk causes a write errror (which might be normal), but the stream exception message dialog indicates at least another mistake.
The error message translates to:
Can't open the drive "\\.\PhysicalDrive0" for writing. System error. Code: 2.
Can't find a specific file.
Possible causes might be that writing to the end of the disk is disallowed by Windows or a driver.
pbies
Re: Error when writing to disk end
Post by pbies »
I am the author of this screenshot.
I suspect also some variable-length problems when dealing with 4 TB disks. (Maybe sector is out of range etc.)
In this case it is SSD, exactly Samsung QVO 860.
The same error is on WD My Book 4 TB external drive.
I just checked right now.
However HxD version 1.7.7.0 does not have any problems writing at the end of these disks.
pbies wrote:
28 Sep 2019 22:01
In that case it is probably an issue with unmounting logical drives on the physical disk.
A range problem is unlikely, since HxD works with 64 bit integers, and it works under 1.7.7.0.
Did it mention that unmounting partitions failed?
Are both disks EFI / GUID partitioned?
I have no disk that large currently to trigger this error though, so it might take a while to fix.
pbies
Post by pbies »
There were no messages about any unmounting. These are simple single full-disk size partitions.
Yes, the disks are GPT formatted but were opened as physical disks.
