how to search and replace in multiple opened files?
cl0cal
Post by cl0cal »
hello, I need to search all occurrences of a hex array and replace it with another one.
This works perfectly with a single file, however I require doing this for over 100 files many times..
I cannot seem to find the way to do it all automatically other than manually laboring each and every file doing the 'search and replace..' how can I achieve this?
Re: how to search and replace in multiple opened files?
Unfortunately, there is no option to do this for several files at once.
cl0cal
Post by cl0cal »
that's a shame :( , your product is just about the cleanest looking gui and high performance I've seen, I know about it for more than 15 years so just wanted to first say thank you !
Any option to request the feature if it's still in active development? HxD can already open multiple files, enabling search&replace through them all at once would be amazing
User avatar
prino
Post by prino »
This is one feature I'd also love to see, although having just finished editing sixty DOS .COM files, I'm not sure when I would need it again.
Robert AH Prins
https://prino.neocities.org/zOS/zOS-Tools.html - Some programming here :mrgreen:
I'll move that to feature requests.
User avatar
prino
Post by prino »
Maël wrote: 21 Apr 2021 18:10 I'll move that to feature requests.
:mrgreen:
Robert AH Prins
