Fixed: ClearEdit, display problem with unicode characters
hwtan
Post by hwtan » 30 Nov 2005 09:11
ClearEdit in win98 seems to have problem displaying unicode character. Although a unicode font is used, I still find that the cursor does not move to the end of a unicode character. Thus, later characters may only partially be displayed or being 'cut' and not displayed at all. I suspect that it has to do with the fix definition in wide.
Post by Maël » 01 Dec 2005 01:28
Thanks for reporting!
Probably you mean display problems with Asian characters.
Internally I fixed this already, but before releasing a new version I first want some other small things done. Expect a new release in max. 2-3 weeks.
Post by Maël » 19 Dec 2005 01:39
Fixed in latest version 1.6.0.0
