Cannot open file for write access. Used by another process.
gekoneq
Post by gekoneq »
Hi! I want to edit file "pakchunk10-WindowsClient.ucas". This file is from the Fortnite game.
So i open Fortnite > open HxD > open file pakchunk10 > edit hex code > and here error appears.
How can i bypasss this thing so i can save edited hex code when Fortnite is running?
Re: Cannot open file for write access. Used by another process.
Ideally you would ask the one who made the tutorial.
Where do you enter it (which colum hex or text?) and what is the error message?
