Done: HxD: extended "select block" option
lordcanty
Post by lordcanty »
Hi, a couple of minor things I'd like to see in HxD.
When using "select block" I hope you could add an option to select from starting point + block length in bytes instead of only ending position. Sometimes I have a starting offset and size, and having to manually calculate the ending offset is a bit annoying. You could make some radio buttons so the second box means "ending offset" or "number of bytes selected".
Also a small comment but it's my own preference so you might not agree. I think the way blocks are selected is a bit misleading. For example if I put as the start-end 0x1000-0x1200 I personally think I'm selecting a size of 0x200, but since the ending offset is included HxD selects 0x201 bytes (I believe this is the same for other functions). A possible solution would be some option to include or exclude the last byte in selections, but it's so minor it would be weird to have such option.
Re: HxD: extended "select block" option
lordcanty wrote:When using "select block" I hope you could add an option to select from starting point + block length in bytes instead of only ending position.
As it happens, I have implemented this in my development version some time ago.
lordcanty wrote:I think the way blocks are selected is a bit misleading.
That is the way it is done in all hex editors I've tested. I wouldn't want to deviate from this behavior as it would lead to confusion to have HxD be the exception.
But apart from that I think it is logic, too. For example: You could say you are on holiday from the 5th day of a month to the 10th day, in total you are on holiday for 10-5+1= 6 days. If your holidays goes from the 5th to the 5th day, you still have one day off, and not zero days.
Ok, on the other hand you could say: I go from meter 50 to meter 50, then the distance would be 0 meters.
Anyway... I'll keep it the way it is for compatibility, the length in bytes option should help if you want to use the "other" logic.
lordcanty
Post by lordcanty »
Ok, thanks. I've checked and indeed that's how others hex editors do it, but it was a minor thing anyway, the length in bytes option is enough for me.
Implemented in version 1.7.1 beta
