Fixed: HxD: Access violation in v1.7.0.0. Beta with Find
tDJ
Post by tDJ » 07 Apr 2007 19:58
Open a file with HxD, press Ctrl+F, enter anything to search for, press OK and you get this error:
Access violation at address 004BB82C in module 'HxD.exe'. Read of address 00000008.
I hope you can find and fix it. Btw this function works fine in v1.6.1.0.
thedutchjewel.defcon5.biz
Post by Maël » 07 Apr 2007 22:03
Thanks for the report.
Yes, I found and fixed it (it happens when you open a file per command line or context menu)
A new version will be up, after some other fixes/bug reports.
Post by Maël » 23 Apr 2007 15:54
Fixed in development version.
Post by Maël » 08 Jun 2007 23:42
Fixed in version 1.7.1 beta
