UniSynEdit
Quiz
UniSynEdit
Post by Quiz » 15 Jan 2009 23:16
hi.
i have tryed to install unisynedit on D2009. it installs fine, but delphi cant find the source files when i try to run my program.
i dont know if i installed it correctly. do you have an install guide?
Quiz
Re: UniSynEdit
Post by Maël » 17 Jan 2009 16:01
That's the same as for all the other component set or the Ansi version of SynEdit.
You have to add the source files to your library and source path in the Delphi-options. Also make sure you delete every DCU or DCP and BPL from ANSI SynEdit if you used it.
