HxD: User manual
pctopgs
HxD: User manual
Post by pctopgs » 23 Aug 2006 20:48
Can you make a user manuel?There probebly isnt much to put in the manuel but sum tips on on handling software.
Thing is, Im havn't proramed a single thing in my life. :roll:
Post by Maël » 24 Aug 2006 12:23
A manual is planned for version 2.0.
You don't have to know programming to be able to use a hex editor.
There are some tutorials out there in the net that tell you the basics about hex editors.
The main question is what do you want to do?
