Add HxD to WinGet Repository
cstayyab
Post by cstayyab »
Hi!
I wanted to add HxD to Windows Package manager for Windows (WinGet). For that we need the following:
  • Make HxD available as Downloadable EXE instead of ZIP file.
  • Provide a Silent Switch with installer that installs HxD without any user input (Unattended)
It would be good for HxD as more and more people will be able install and use it easily.
Regards
Re: Add HxD to WinGet Repository
Thanks, that's a good suggestion.
What would unattended mode chose as options, only the default, or is there a way to configure setup?
cstayyab
Post by cstayyab »
Unattended mode would be setup as default options only. Like Default install location (C:\Program Files) etc.
