An option to select byte order when searching for HEX values
Posted: 28 Oct 2021 15:40
In the Find dialog, if a user searched for the following HEX value: 5EB39037, HxD will not return 3790B35E in the search results even though the only difference between the two values is endianness.
I should also note that this option has already been implemented for the integer search.
Thanks and best of luck!
