Comparison results child window gets lost after switching away from HxD
vertigo
Post by vertigo »
When running a comparison on identical files, if you switch to another program and then HxD finishes the comparison, not only is there no indication of when it finishes the comparison, but switching back (via alt+tab or the taskbar), the results window doesn't show. You have to either alt+tab away and back again to get it to show or quickly click the taskbar button a few times to cycle HxD's focus. This has been an issue for quite a while, and Windows 10 has some pretty glitchy focus issues in general, so that may be the cause, but it's very consistent with HxD. I'm using 2.5.0.0 with W10 Version 21H2 (OS Build 19044.1826).
