Page 1 of 1
Access violation when dragging tabs
Posted: 11 Sep 2024 11:23
by aldorn
Access violation due to pointer truncation at RVA 0x57AA7E / file offset 0x179E7E.
You might have to enable High Entropy ASLR to reproduce this.
Here's a patch in case anyone needs it:
Replace 89 C6 48 63 F6 with 48 89 C6 90 90 at the above-mentioned file offset.
Re: Access violation when dragging tabs
Posted: 21 Oct 2024 13:26
by Maƫl
Thanks that was a VCL (Delphi) error as well, wrong return datatype. Took quite a bit of searching with the hex data, but I found it and fixed it in the source code, so in future this patch won't be necessary.
