I haven't found this feature request in the history of this board.
I have a huge file which begins with many #00h.
I have not found a solution to jump to the beginning of the first datablock.
The mouse is too jumpy / jumps too far, I cannot fix the first beginning of the block.
I have to klick to the file and scroll up/down with the keys Page UP and Page Down.
But with the mouse jumps too far, the Page Keys are too narrow.
Second, the data blocks are devided by #00h, I haven't found a solution to just "mark" the data between that #00h-borders.
(Yes, I know it is possible to search for #32h as example, but if it isn't in the block you miss that data)
So I think a good feature will be something like that :
- search beginning of data-block (maybe with configurable hex value ?)
- search next / search end of data block
- mark between beginning and end
Thank you for your good hex editor.
AndreWas
