Page 1 of 1
Fixed: HxD: Access violation when using file compare
Posted: 15 Apr 2007 11:53
by Schtrudel
I got such error in File Compare:
at 004089CE in module HxD.exe . Read of Address 7FE80000
Furthermore, it's also weird that if I click somewhere in on the file, the whole compare is after that "out of sync"
Thanks
Schtrudel
Re: Error in File Compare
Posted: 15 Apr 2007 12:13
by Maël
Schtrudel wrote:I got such error in File Compare:
I could not reproduce it, please tell me the single steps. (Did you use the Windows context menu, opened the files directly, how many of them, in which order). Thanks.
If "out of sync" means that when you click somewhere in the window, the compare continues where you clicked, then this is expected behavior. There will be a results window in future, so you can change the caret-positioning without it affecting the compare.
Posted: 15 Apr 2007 13:38
by Schtrudel
To reproduce the problem, I opened to almost equal files (by regular Open icon on HxD). The files are exe files, one of them the "patched" version of the second; 2.7MB. I compared them, and I began moving along back and forth over the changes with F6 and Shift-F6. Most of the times on the "borders" (first and last change) I got the error, but was able to continue working on the files after closing the errors.
Posted: 16 Apr 2007 01:12
by Maël
(Note: I split the thread into two as the other bug was unrelated).
Could you perhaps send me those files? It would make it easier than trying to create files that cause the bug to appear.
You can send files to
Posted: 18 Apr 2007 17:26
by Maël
Okay, this fixed the problem with the example files (you sent me), and it very likely should fix the problems with the files you used.
You can get the (German) development version that includes the fix here:
http://mh-nexus.de/downloads/HxD.zip
Could you please confirm it works with your "original" files, too?
Thanks,
Maël.
Posted: 23 Apr 2007 15:51
by Schtrudel
Except that it's in german, it works ok !
Thanks
Posted: 23 Apr 2007 15:53
by Maël
Fixed in development version.
Posted: 23 Apr 2007 15:57
by Schtrudel
BTW, you put this development version at the place of the released one... Does this mean that 1.7.1.0 Beta German edition is a released version
Juuuust kidding
Posted: 23 Apr 2007 16:00
by Maël
I didn't, note that the filenames are different: HxD.zip, HxDBetade.zip and HxDde.zip.
Posted: 23 Apr 2007 16:15
by Schtrudel
My bad!
So, no development version in english?
Posted: 23 Apr 2007 16:29
by Maël
There will be a second beta after some other bugs are fixed.
Posted: 08 Jun 2007 23:41
by Maël
Fixed in version 1.7.1 beta
