Fixed: HxD: Adapt to window width option
Bryan
Post by Bryan » 01 May 2007 17:19
The Adapt to window width Option is not tied to the function.
The function works when selected from the Toolbar button or View menu.
This is very minor bug.
Post by Maël » 01 May 2007 21:37
When you choose "Adapt to window width" in the option dialog it should apply to new windows, but shouldn't affect the old ones.
If it doesn't apply to new windows then it is a bug, in the other case this is intended behavior.
Bryan
Post by Bryan » 01 May 2007 21:41
That wasn't obvious, maybe you could change the option to "Adapt new windows to window width" or add a comment underneath the option.
It works exactly as you say.
Thanks,
Bryan
Post by Maël » 01 May 2007 21:55
It applies to all options on the View-tab. I'll think about how to make this more intuitive.
Post by Maël » 08 Jun 2007 23:40
Fixed in version 1.7.1 beta
