Fixed: HxD: Trouble opening files when open methods mixed
mhurley
Post by mhurley » 16 May 2008 18:28
With 1.7.6
1. Make sure the HxD folder is in your PATH
2. Open some files with the right-click context menu. Refer to these files' folder as FOLDERA.
3. Go to a command prompt window and CD to a different folder than the files opened in step 2. Call this FOLDERB.
4. Run "hxd FILENAME"
5. HxD will show a message box saying "Cannot open FOLDERA\FILENAME for read access" when it should have shown (and tried to open) FOLDERB\FILENAME.
Re: HxD: Trouble opening files when open methods mixed
Post by Maël » 06 Jun 2008 18:53
Thanks for the report.
It was a problem due to different working directories in different HxD instances. When a file name is not prefixed with a path (such as when passing just a file name using the cmdline) the the wrong working directory was assumed (the one of the already existing instance instead of the newly created one).
Fixed in development version.
Re: Fixed: HxD: Trouble opening files when open methods mixed
Post by Maël » 07 Aug 2008 18:41
Fixed in version 1.7.6.4 (will be published today)
Post by Maël » 08 Aug 2008 21:41
Ok, finally uploaded the new version (1.7.6.4).
