Fixed: Confusion of files with the same name in diff. dirs
llwang
Post by llwang » 22 Jun 2008 08:15
It seems that if different files of the same name stored in different folders are opened together, HxD will always think the second file is identical to the first. For example, if we have two files C:\foo\foo.txt and C:\bar\foo.txt, open the first one, change it, and save it, then open the second one, we'll see that the second one will become identical to the first, while in fact they are different.
Re: Confusion of files with the same name in different folders
Post by Maël » 25 Jun 2008 03:02
Thanks for the report.
It is a variation of the bug reported in http://forum.mh-nexus.de/viewtopic.php?f=3&t=233
Re: Fixed: Confusion of files with the same name in diff. dirs
Post by Maël » 07 Aug 2008 18:38
Fixed in version 1.7.6.4 (will be published today)
Post by Maël » 08 Aug 2008 21:41
Ok, finally uploaded the new version (1.7.6.4).
