I tested that with version 1.7.6.4:
Open 2 hex files
Open the Statistics view
- switch from the drop down list to the second file -> The view is not updated
- right click and Hide Maximum -> The view is not updated
The view get updated line by line if you move the mouse over the view, or at once if you resize the window.
Thanks
Schtrudel
Fixed: "Statistics" view updates
Re: "Statistics" view updates
I send it to you by mail...
Thanks, I replied to you by mail.
Fixed in developer version.
Re: Fixed: "Statistics" view updates
Fixed in version 1.7.6.5
