Fixed: HxD: Search&Replace does not replace all occurren
testj
Post by testj »
I just found a little bug in HxD's search and replace algorithm. I tried to delete the linebreaks from a textfile with about hundert lines and in each line one ascii char.
I used search&replaxe in hex data mode with "0D 0A" as search phrase and an empty replacement. After running the replacement operation every second occourence of "0D 0A" is left over which is not as it should be (IMHO)...
Yes, I can reproduce this, it happens when you choose "replace all".
Thanks for the report, I'll look into it.
Fixed in actual Beta.
Beta will be available shortly for everyone to test.
