Different Checksums
Blackmarket
Different Checksums
Post by Blackmarket »
when i open a File and make a complete Checksum I always get different values for the same file when i click on refresh. Do you know why?
Re: Different Checksums
Probably you have opened a file that is constantly changed (outside of HxD), so the checksum will change accordingly. It isn't necessarily obvious when HxD automatically reloads the file (Future versions will have a non intrusive way to notify that a file was reloaded).
Please test it with another file that you are sure does not change (for instance a text file that you just created). In that case the checksum should not change either.
