Ability to Turn OFF File and Search Pattern History
Shodan816
Post by Shodan816 »
Just tried your hex editor for the first time and it is GREAT. One suggestion for improvement would be the ability to turn off the logging of Recent Files and Recent Searches in the INI file. I tried setting the INI file to 'read only', but the executable didn't like that too much. :-)
Thanks for listening ! !
Gary Jennings
Matthews NC USA
Re: Ability to Turn OFF File and Search Pattern History
Yep. This is scheduled for the next version.
Toad
Post by Toad »
Ha. I requested this before also http://forum.mh-nexus.de/viewtopic.php?f=4&t=279 . Can't wait until the next version comes out!
jackoma
Post by jackoma »
As a temporary solution, I included the HxD.ini file at
\AppData\Roaming\Mael\HxD
on CCleaner's delete list.
