Done: HxD: Text only/Hex only view
Abe
Post by Abe » 23 Mar 2006 15:49
I would be really nice to have HxD have an option to show or hide the Hex portion or Text portion. I have a really large text file (1.6GB) where I am only interested in the Text portion. There are very few editors capable of loading the file but HxD opens it just great. The only problem is I can't hide the Hex portion and only view with the Text portion.
Thanks
Dean
Post by Maël » 23 Mar 2006 19:55
Hi Dean,
I could add this feature. However text would still be displayed as a "block", i.e. linebreaks will not be displayed like in text editors, so reading large parts of text could become difficult.
Is that okay for you?
Abe
Post by Abe » 30 Mar 2006 12:28
Maël wrote:I could add this feature. However text would still be displayed as a "block", i.e. linebreaks will not be displayed like in text editors, so reading large parts of text could become difficult.
I was waiting to get an email from the forums saying there was a reply :). That would be cool. It would be sufficient to make out the majority of what is going on.
Cheers
Dean
Post by Maël » 30 Mar 2006 14:23
Abe wrote:I was waiting to get an email from the forums saying there was a reply :).
Hm, I looked up your configuration, e-mail notification is active. Perhaps you unchecked it when composing your message.
Did it work this time?
Abe wrote:It would be sufficient to make out the majority of what is going on.
What do you mean by that? I don't understand.
Abe
Post by Abe » 30 Mar 2006 20:16
Maël wrote:Did it work this time?
Ouch, this was my fault. I put the wrong email address in.
I meant that even with the "block" it would be enough to read the text to see what was happening in the file.
Thanks
Dean
Post by Maël » 31 Mar 2006 15:00
Okay, added to TODO-list.
Abe
Post by Abe » 31 Mar 2006 19:43
Thanks a lot.
Cheers
Dean
Post by Maël » 21 Aug 2006 20:06
Done in developer version.
Will be included in comming beta.
Post by Maël » 04 Apr 2007 14:06
That feature request is pretty old, but finally there.
See actual beta version in download section.
