Fixed: Failed to get object at index 0
inertially
Post by inertially »
Open a file in Hxd.
Then open the same file
The tab flashes, right click and close the first time and you get
Re: Failed to get object at index 0
Thanks for the report.
Which version of HxD?
inertially wrote:The tab flashes, right click and close the first time and you get
Close the "first time" means "close the only tab there is"?
How do you open the file? Drag&drop, menu file|open, using Windows-Explorer context-menu or command line?
Edit: OK, I see you have to do it while the tab is still flashing.
Fixed in development version.
