File compare enhancements
takasuite
Post by takasuite » 18 Aug 2009 02:22
i have a few features to request, if you see they are suitable features
-When comparing two files, i would like to have mark red on both file,
when i scroll bar, both file move together. ( like Total Commander )
For Big file, i can't press F6 so long, console runs next byte
-When i press Ctrl+g , i don't see where the console is , could you inverse the color of console ? or an option for changing it )
-Windows view, add Title Vertical, because now people have Wide screen
-When i mark block by Ctrl + left ( right) arrow , then cheksum CRC, i want to move back or forward marked block by Ctrl + left (right ) arrow, the file name change on window CRC checksum, not the marked block
by the way you offer a great free Hex editor tool.
thanks very much,
Re: File compare enhancements
Post by Maël » 22 Aug 2009 18:44
If you find a bug or want to make a feature request next time, please create a new thread/topic for each request/report.
Please describe more clearly. The difference is highlighted by the selection in both editors.
(What console, or do you mean cursor/caret?) Making a very big guess you probably want block-based file compare.
That's on purpose to follow Windows design guidelines. If you can explain why you need it I may find another solution.
Ok
Does this mean you want the checksum window to be focused after pressing ok in the checksum dialog?
