Fixed: Garbadge display on more then 32 bytes per row
smeezekitty
Post by smeezekitty » 06 Oct 2009 02:01
i attached a picture::::
smeezekitty
Re: Garbadge display on more then 32 bytes per row
Post by smeezekitty » 09 Oct 2009 07:03
Hello Mael,
my os is windows vista SP 1
its regardless of the graphics driver or file loaded it looks distorded
i think u will agree from da pictre above
Post by Maël » 09 Oct 2009 20:21
What version of HxD are you using?
smeezekitty
Post by smeezekitty » 09 Oct 2009 23:58
1.7.6
Post by Maël » 10 Oct 2009 00:05
The newest version which is out since April is 1.7.7. This version should have this bug fixed.
smeezekitty
Post by smeezekitty » 10 Oct 2009 00:32
its fine in the new version
Post by Maël » 10 Oct 2009 01:01
Please, check the new version before posting a bug in future. It reduces the time I spend trying to reproduce a bug.
smeezekitty
Re: Fixed: Garbadge display on more then 32 bytes per row
Post by smeezekitty » 10 Oct 2009 02:54
it also fixed the ext2 stream read error
