Won't Do: Slider MUST BE always big bithin
mad9006
Post by mad9006 »
not comfy when file to big, for quick visual file identified scroll button sux, and when you try use that fucn thick slider, you $%$^$^
my eng poor so see images
default thick shit
slider must be always big, even if file biggest one
Re: Slider MUST BE always big bithin
That's the way Windows works. It decides how large the thumb button (slider) is, which is dependent on the amount of data that you can scroll. I don't know it off hand but maybe you can set a Windows-wide minimal size for the thumb button.
It's usually not useful to scroll using the thumb button in large files anyway since you scroll very far very fast.
Use pageup or pagedown or click on the "empty" slider zones to scroll instead.
