Fixed: The chosen files are identical. The file sizes are different
Cor'e =)
Post by Cor'e =) »
"The chosen files are identical. The file sizes are different, though!"
What parts of the files are not being compared? Is there a option to hex view/compare all parts of a file? (WinXP Pro x32 SP3) Tia! =)
Re: The chosen files are identical. The file sizes are diffe
Cor'e =) wrote:"The chosen files are identical. The file sizes are different, though!"
The real meaning is: The beginning of the larger file is identical to the entire smaller file.
This will be changed in the next version.
Re: The chosen files are identical. The file sizes are different
It was changed in HxD 2.0.
