Fixed: HxD: ANSI charset does not depend on default codepage
alkisg
Post by alkisg »
Hi Maël,
on a PC with Greek as the default system locale for non-unicode programs, shouldn't chars in the range [$80..$FF] be displayed using windows-1253 codepage?
Simply put, if I open an ANSI text file on HxD, I can't see Greek chars, I see the equivelant windows-1250 chars...
You can use GetACP to detect the system ANSI codepage.
Regards,
Alkis
Hi Alkis,
you will see the Windows-1252 charset as I hardcoded it, due to drawing problems there are when HxD is used on Asian systems (multibyte-issues).
I thought of a solution also including UTF-8 support, meanwhile I could implement a way to use the charset from the system locale if it is non-multibyte or switch back to Windows-1252 if it is.
Maël.
Fixed: Used the user locale for non-multibyte charsets.
