Record Color Coding/Display Number of Records
lonnieeining
Post by lonnieeining »
Re: Record Color Coding/Display Number of Records
With records do you mean chunks of the same size, or a structured view (like struct or record in programming languages)? If you mean the former, then you can open a file as a disk image (Extras|Open disk image) and enter the desired record size where usually you would enter the sector size.
This will give you divider lines between the records, and a navigation toolbar which tells you at which record/sector you are and the total count of records/sectors in the file.
Except of that special treatment everything else works as for normal files (File|Open).
