HxD offset help
bomer20
HxD offset help
Post by bomer20 » 16 Oct 2010 23:07
I'm converting MKV files to Blu-ray files using tsMixer,HxD, BDedit and image burn. One of the last steps is to change the value in HxD where the offsets meet. How do I tell where the offsets meet? The instructions I found on brothers grim looks random when finding the meeting of the offsets. Thanks for your time.
Re: HxD offset help
Post by Maël » 17 Oct 2010 02:19
I am sorry I can't give you specific help on how to do that, just general help on how to use HxD. You can try and ask the people that told you how to convert MKV files on how to solve this issue.
bomer20
Re: HxD offset help
Post by bomer20 » 17 Oct 2010 05:46
Thanks. I'll give that a try.
