Save named view settings
pTd
Post by pTd »
I would find it useful to save modified views as named settings available from the view menu.
For instance my default view is 64 bytes, 16 byte groups, hex and text, but currently I modify this to 188 bytes per line, text, no hex, for examining .ts packet structure. This would be much easier if I could select it from the view menu as a previously saved 'Packet' setting for example.
