Add Japanese Shift-JIS text encoding support
Posted: 03 Apr 2012 05:19
First, I thank you very much for the excellent hex editor you have created. Since I discovered HxD, I rarely use anything else and I appreciate your work.
It's common to deal with Shift-JIS files in the translating community and few hex editors support it. Ultra Edit is used by most translators, but it is costly, needlessly complex and has an unintuitive interface (unlike HxD). I think adding Shift-JIS support would be quite useful.
Thank you
Thank you
