Done: Search > Find All
UncleRemus
Post by UncleRemus »
Is there a way to run a search to find and highlight all occurrences of a block of data?
i.e. if I noticed a common pattern "0B 7A D1 06" and ran this "search all" it would pop up a window with all the occurrences of this block and listed all offsets to the finds and maybe even click/double-click to jump (go to) that offset
Also, the hex data would look like so:
01 A3 32 19 00 28 0B 7A D1 06 00 21 AF 04 FF 0B 7A
D1 06
82 1B 19 77 0B 7A D1 06 00 7A 2F 20 14 00
and so on....of course the bold and underline is just because the forum format limitations it would probably be highlighted
if not, can you move this to the requested features it would be soooooo sexy for us file analyzers!
Re: Search > Find All
A findall feature with a list of matches that is highlighted is in the making.
Owyn
Post by Owyn »
Maël wrote:A findall feature with a list of matches that is highlighted is in the making.
thx... looking forward to it.
Find all exists in HxD 2.0 and up.
