Command Line Options?
mfonseca
Post by mfonseca » 23 Feb 2015 23:16
Hi, I like a lot the HxD editor for its flexibility, and was wondering if there is a list of command line options for invoking it.
I would like to write a batch file that invokes a working environment for an elder user who needs to have HxD open a specific file as Read-Only in order to perform manual searches on it, so I don't want the user to do it by himself, in order to prevent him from accidentally damaging the data file.
Any help appreciated. Thanks in advance,
Miguel
Re: Command Line Options?
Post by Maël » 24 Feb 2015 15:02
Hi Miguel,
You can open a file by passing it to HxD on the command line:
HxD.exe <filename>
, where <filename> may have to be enclosed in " if it contains spaces, as usual for any program under Windows.
Except for this option, HxD unfortunately has no command line support.
DVV
Post by DVV » 08 Oct 2018 16:59
Does the latest version of HxD include some additional command line switches, if any?
I remember there were several forum's threads about the command line switches/options, but the readme.txt does not seem to mention any.
Post by Maël » 09 Oct 2018 00:40
Nope, there are none, besides the ability to open files.
