Cannot reproduce: error creating hxd.ini
ronchristie
Post by ronchristie » 01 Jun 2015 22:49
Hi Mael,
When using HxD on a Windows 7 machine, if I load it from the desktop via a shortcut icon I get:
Cannot create file "C:\Program Files\HxD\HxD.ini". Access is denied.
If I right-click the shortcut and choose "Run as Administrator", then everything works as expected, so there is a workaround, except...
If you're trying to use the tool on a remote desktop where (depending on the host OS version) the security question isn't transmitted, it effectively hangs your session. :cry:
Re: error creating hxd.ini
Post by Maël » 03 Jun 2015 22:46
Did you use the setup program or did you use the portable version of HxD and moved the exe-file to the "Program Files" directory manually?
If you used the setup program this error should not occur.
