Question
ch3vy
Question
Post by ch3vy » 06 Nov 2015 09:41
Hello
I'll just get right to it,
I need to put number 625 in HEX which is "27 1"
But, when I enter the digits I have 4 spaces to enter. so if i put 27 10 value changes , if i put 27 01 the value still changes..
Any solutions?
ch3vy
Re: Question
Post by ch3vy » 07 Nov 2015 14:34
ch3vy wrote:Hello
Any solutions?
Figured it out myself hehe, really easy mistake though, instead of typing "27 1" i had to type "2 71", for those of you who might happen to have similar issue ^^
Re: Question
Post by Maël » 07 Nov 2015 22:39
Thanks for getting back here after you found the solution.
