Done: Import Motorola/Intel: limited to certain file extension
busybee
Post by busybee » 11 Apr 2017 11:57
I had a look on the 2.0 RC
The open dialog shows only the files which fits to predefined list.
For Motorola for example, you accept only:
Motorola S-Record (*.mot; *.srec; *.s; *.s19; *.s28; *.s37)
May you can expand that with an alternative entry
All Files (*.*)
so all the other files can be picked too. We are using "mhx" as extension for these files (even if it is non standard).
I think, it will work similar to this:
Filter := 'Motorola S-Record (*.mot; *.srec; *.s; *.s19; *.s28; *.s37)|*.mot; *.srec; *.s; *.s19; *.s28; *.s37*|All Files (*.*)|*.*;
Re: Import Motorola/Intel: limited to certain file extension
Post by Maël » 15 Apr 2017 01:59
Added "all files" filter for importing in the current release candidate.
The download link is the same as before: https://mh-nexus.de/downloads/HxDSetup.zip
Re: Done: Import Motorola/Intel: limited to certain file extension
Post by Maël » 06 Feb 2019 15:39
Available as stable in HxD 2.0 and later.
