silent installation
nalbe666
silent installation
Post by nalbe666 » 29 May 2017 11:48
Hello! Is there a way to install HxD in silent mode?
Re: silent installation
Post by Maël » 30 May 2017 11:55
I use InnoSetup which has silent mode command line options (/SILENT, /VERYSILENT). So that's what you would use in HxDSetup.exe or Setup.exe.
http://www.jrsoftware.org/ishelp/index. ... tupcmdline
But I haven't specifically tested the setup with these options. Let me know how if it works for you.
