Shadow Warrior godmode, infinite ammo
Stichling
Post by Stichling » 25 Aug 2017 11:32
Hallo,
PC Game Shadow Warrior godmode, infinite ammo
With the hex editor you can create your way through this game,
i.e. with Hex editor you can change values.
The following steps should be carried out:
1. Open sw.exe (Shadow Warrior.exe) with your Hex editor
2. Search for 'damage to player' / ' infinite ammo'
3. Change the value from '1' to '0'
4. Save the file.
5. Enjoy your Godmode / Infinite Ammo
My hex editor show the following figures ( see attachments )
But now I need help.
Can you explain me how/where shall I change the value from '1' to '0' ???
Thanks
infinite ammo.gif (88.5 KiB) Viewed 3994 times
damage to player.gif (88.9 KiB) Viewed 3994 times
Re: Shadow Warrior godmode, infinite ammo
Post by Maël » 26 Aug 2017 16:32
They probably mean that you should change the 0 in the text column (=right colum) to 1.
For example: "Infinite ammo...0" to "Infinite ammo...1".
Make sure you don't change anything else, so really click on the 0 and type 1, then save.
