Fixed: Alt key does not activate menu, Alt+ accelerators do not work
dcapwlii
Post by dcapwlii » 16 Dec 2017 01:31
When I press an Alt key in 1.7.7 it activates a menu bar so that I can navigate through it with keyboard (like in any other native Windows program). But when I press Alt (or Alt+F, or Alt+E, for example) in 2.0.0 it just beeps. I am using 32-bit Windows XP SP3 and English/US keyboard layout.
Re: Alt key does not activate menu, Alt+ accelerators do not work
Post by Maël » 18 Dec 2017 07:26
Thanks, I can reproduce it. It also happens under Win8.1 German.
For some reason it works fine in the debug build, but not the release build. I'll investigate.
Post by Maël » 19 Dec 2017 16:20
Found the bug, was due to an error in the toolbar code, that used a Char (=WideChar since D2009) as an AnsiChar. So part of it was not initialized in Release mode.
When the fix is in the download I'll update again.
Re: Fixed: Alt key does not activate menu, Alt+ accelerators do not work
Post by Maël » 21 May 2018 21:36
Fixed, see current download.
