Fixed: Data inspector confusing behavior: hexadecimal display, but decimal input
dcapwlii
Post by dcapwlii » 16 Dec 2017 01:47
When "Show numbers in hexadecimal base" option in data inspector is turned on then data inspector shows numbers in hex. However when I try to modify such number it says that a number is not valid. To make it valid I have to manually prepend a 0x prefix. I think that data inspector should either always display hexadecimal numbers with a prefix or somehow allow hexadecimal input when hexadecimal display is turned on.
Re: Data inspector confusing behavior: hexadecimal display, but decimal input
Post by Maël » 19 Dec 2017 16:23
Added a hexadecimal convertor for integers when the display as hexadecimal option is enabled.
When the update is live, I'll post again.
Re: Fixed: Data inspector confusing behavior: hexadecimal display, but decimal input
Post by Maël » 21 May 2018 21:35
Fixed, see current download.
