Fixed: Color sometimes changes to the right of the selected area
Homer
Post by Homer »
HxD 2.0.0.0 (03 Nov 2017, 01:13 CET)
Good:
good
good
Bad:
bad
bad
Re: Color sometimes changes to the right of the selected area
Thanks for the clear report.
To trigger the bug, you need to have scrolled horizontally apparently.
A simpler testcase is this:
32 bytes per row, byte groups of size 4.
Scrolling one bytegroup to the right (first visible column is 0x04).
Selecting any column (for example 0x08 to 0x0C), then pressing F5.
Selecting part of any column (for example 0x08 to 0x0B) causes related but slightly different drawing bugs.
Another interesting testcase:
(No scrolling yet.)
Select bytes 0x1 to 0x2. With each scrolling the color after the selection change, but this time part of each column is colored differently. The parts of each column switch their colors too, when you scroll further.
Should be fixed in the latest release.
Please confirm.
