Fixed: Scrolling on Windows 10 tablet problem
Scroller
Post by Scroller » 04 Jun 2018 11:09
There is a problem with scrolling on a Windows 10 touch screen tablet in HxD 2:
Swiping up and down on the hex editor area does not scroll, instead it selects text rather than scrolling.
With HxD 1.7.7 on a Windows 10 touch screen tablet, swiping on the Hex editor area will correctly scroll as expected.
So this is a new problem with HxD 2.0rc
Re: Scrolling on Windows 10 tablet problem
Post by Maël » 04 Jun 2018 19:51
Thanks for the report. However I don't have Win10 tablet to test.
Probably it has something to do with the new support for touch in newer Delphi versions.
Post by Maël » 14 Jun 2018 23:06
Usually, you have to double tap to select, maybe the double click setting in Windows is too low, so it seems as if there was a bug? It could also be that you ran HxD as admin. Some extended functions are not available then, depending on your mouse/touch/etc. driver.
Either way, I would need to add some extensive logging to HxD or do a remote debug session to fix this, as mentioned above.
Scrolling with a touchpad under Win8 works fine.
P.S.: Using a fake email for privacy is fine, but if you don't check it/or check this post, that doesn't make much sense for a bug report...
Re: Fixed: Scrolling on Windows 10 tablet problem
Post by Maël » 10 Oct 2018 09:46
Fixed in the current development version.
It was indeed a bug in the new VCL of Delphi since touch support was introduced.
The bug can be reproduced with the Windows Simulator that gets installed by Visual Studio.
C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Simulator\15.0\Microsoft.Windows.Simulator.exe
This allows to use the mouse to create touch gestures (single or two-finger touch). A user of DP confirmed that it fixes the bug also under Win10/Surface 3.
Post by Maël » 17 Jan 2019 00:15
