I'm not quite a fan of the new 'Decoded text' line above the hexadecimal output, and I ended up using the old HxD to remove it from the new HxD (
HxDception?!). I propose adding a simple checkbox above 'Fit to window width' inside the 'Layout' group, possibly 'Show decoded text header' or something along the lines.
Here's how my modified version looks (I love how clean it looks!):
Thank you so much for the new version, I can't believe it's been available since 2017! Very, VERY happy with it so far!
