Floating point numbers are tricky. Interestingly I have been writing toy programs recently to convert floats to floating point binary strings (not floating point decimal) and back to their IEEE single or double float formats.
This requires more research to be done correctly, for now I'll rely on the Delphi internal StrToFloat/FloatToStr functions.
Some notes follow.
When considering how many digits to display, various factors have to be considered.
One major question is whether round-trip data conversion should merely not introduce errors (i.e., x==StrToFloat(FloatToStr(x)) should be true) and other digits that do not affect this result should be truncated or rounded off.
Or should the actually accurate representation as decimal float be shown, that most closely matches the binary float, even if it would not affect round-trip conversions?
Regarding the first option,
Wikipedia (or the referenced paper) claims that:
"If an IEEE 754 single-precision number is converted to a decimal string with at least 9 significant digits, and then converted back to single-precision representation, the final result must match the original number.[5]"
This means: x==StrToFloat(FloatToStr(x)) is true if FloatToStr(x) has at least 9 significant digits.
This site states other values:
https://www.exploringbinary.com/decimal ... t-numbers/
But it also states that for the other round-trip direction only 6 significant digits need to be considered:
If a decimal string with at most 6 significant digits is converted to IEEE 754 single-precision representation, and then converted back to a decimal string with the same number of digits, the final result should match the original string.
This means: x==FloatToStr(StrToFloat(x)) is true if x has at most 6 significant digits and the result or the right hand side has at most 6 significant digits as well.
An example to show the difference between accurate representation, and round-trip data retention:
Consider the value 0x3F800001 which is an IEEE 754 encoded single precision float.
It corresponds to this binary number:
0 01111111 00000000000000000000001
The sign bit is 0, the exponent is 01111111 = 127. Since the exponent is biased by 127 in single precision float format the actual exponent is 127-127 = 0.
Now on to the 3rd binary number, the significand.
Only the right most bit (bit 0) in the significand is set.
bit 0 = 2^-23 * 1 = 0.00000011920928955078125 (exactly)
bit 23 = 2^0 * 1 (implicitly set to 1 for normalized representation)
So the accurate number would be
(1 + 0.00000011920928955078125) * 2^exponent =
1.00000011920928955078125 * 2^0 =
Rounding to just 6 digits would make it indistinguishable from 1.0.
Indeed, when you round "1.00000011920928955078125" to 9 significant digits (1.00000012) it converts to single float format and back to a decimal string correctly.
Some references:
https://www.exploringbinary.com/maximum ... nt-numbers
https://en.wikipedia.org/wiki/Single-pr ... int_format
Lecture Notes on the Status of IEEE Standard 754 for Binary Floating-Point Arithmetic (page 4)
https://stackoverflow.com/questions/509 ... -to-string
https://github.com/JackTrapper/Exact-Fl ... g-Routines
https://github.com/rkennedy/exact-float
John Herbsters ExactFloatToStr(x:Extended)
Other useful contributions by John Herbster:
https://cc.embarcadero.com/Author/358
https://stackoverflow.com/questions/302 ... r-the-hood
Best explanation and summary:
Good explanation, nice research and literature review (4 papers) on printing floating point numbers, including the reference functions written by David Gay:
http://www.ryanjuckett.com/programming/ ... t-numbers/
Two other relevant papers (apparently discussed in the link above):
https://www.cs.indiana.edu/~dyb/pubs/FP ... PLDI96.pdf
Most recent (2010):
https://www.cs.tufts.edu/~nr/cs257/arch ... printf.pdf
Another more recent option used in Swift:
https://github.com/google/double-conversion/issues/27
