Done: file hashes in the download pages
hexadecimal
never use md5 and/or sha1 for the file hashes, use sha512 or better
hexadecimal
Digital Signature?
ok, but you are still using sha1.
use sha256 or better for the file hashes.
Re: file hashes in the download pages
Merged with previous topic.
If you need it now, check here:
https://mh-nexus.de/updates/HxDCurrentVersion.json
Otherwise, just wait until the website is updated (I can't just print it out like this, sha512 is huge).
Every download has now a popup, which lists the corresponding SHA-1 and SHA-512 hashes.
