selection length view in decimal
CrytoGen
Post by CrytoGen »
Can you add selection length view in decimal? Then I can select desired block and select displayed columns number.
Re: selection length view in decimal
Maybe you don't know, but you can switch the offsets to decimal or octal (by clicking on the offset-label, changing the offset-base in the menu, or using the drop-down-box that says "hex"). Then all the other offset-related numbers, such as block length are also displayed in decimal/octal.
You'll see a (d) for decimal that indicates this.
If you meant something else, please state it more precisely.
