Context menu for search results: copy as text, copy offsets, copy hex
Dairymoose
Post by Dairymoose »
After using the Find Dialog and selecting Search All, the offset/excerpt list that appears in the "Search" tab is not interactive. As a feature request, it would be useful if there was a context menu or button that could be used to copy the results to the clipboard. As it stands, getting a list of all offsets from the search results would require manually transcribing them or extracting them from HxD's program memory. Thanks.
Re: Copy as Text for Search All
So you want a context menu for the search results window to copy all the selected search results.
Either the text, hex or offset columns, or all three of them at once.
I clarified the title and extended your feature request a bit.
fzabkar
Re: Context menu for search results: copy as text, copy offsets, copy hex
Post by fzabkar »
I would also like this feature.
"Either the text, hex or offset columns, or all three of them at once."
